:) hot lol
:P hahaha that backfired funky u dog
Sideways skids are awwwesome :):D
<3
y not just get it fixed?
yeh in the process mate - insurance guys just gota get their shit sorted :)
Tristan if u buy a 31, u will die. ill personal see to that.
what if its a 2 door 31 with 15*12 rears with 205 tyres... ..allround..
hahahha naa ill keep the 32 :)
Nah like epic angle skids.
bahahahahaha. So true
for the first comment you're a mado, and ukeep tellin ppl as ur the only one who really experienced the delicious-ness
for last comment you're a straight up dog
Yer tis pretty dog eh. Your not that bad. At least you don't wear your skinny jeans when you come out with us lol
hahaha might havta if my car is in the shop,
ill be busing it from uni
eeep
*flame suit on*
you'd put a change of clothes in your bag. God knows you'd never live it down if you wore skinnys around us haha. Riding a bike in skinnys would suck anus aswell :)
if you get a quote high enough to write it off, I know of a 32 gtr for sale on that price.. not as neat as collins but hot..
or perhaps you could consider upgrading to SR? :)
or perhaps you could consider downgrading to SR? :P
just had to edit your post for accuracy :)
*Drools*
Such a hard decision, do I get a 31 project or a 32 project. All I know is the MYY34 will be jealous lol :)
or just put cash into my 32 :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
