its not that different to yours... you just need more wide, more low and more epic fitment.
i don't give a rats arse if they have angel eyes or not... I need an HID that comes with a lens that's less than 3" diameter and is able to take a H4 dual beam.
so I can put it in this:
sorry, but epic FAIL
wonder how vicroads wud like them...:ermm:
vicroads will like what I let them like. pretty much all HID's are illegal anyways, cos they don't self level... so meh.
oh look out, its Dave, master of the universe and all that is R32s. Get back to me when you have one n driving condition sunshine.
wow, u woke up on the wrong side of tas's bed. its an opinion champ. no need to bite my head off :ermm: as for driving condition... one day.
tas' bed's in QLD and I'm in VIC. logic fail. lol.
if u took a more positive attitude on the subject i would be more inclined to suggest the right item for you..
eh?
ps: thanks for the heat wrap :ermm:
no worries, it was bought for you specifically, not found at the workshop as tas might have mentioned.
speakin of which, i gotta go back to the shop tomorrow and change those headlights over.
more people should be like that. you help me i help you. :ermm: even if you just found it its still kool, saves me cash on the proj.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
