I’m not sure why anyone would be running a street tire up front and a semi on the rear. You could get away with a semi on the front and a street on the rear, however again not sure why.
I personally am not a fan of mix and matching tires
Neither am I. I only tried the semi slicks on the rear once since I had a pair available, to try and get more traction. It was aweful, I won't do it again :)
Old mate earlier in this thread (I forget who it was now ;)) said he was getting semi slicks put on the rear for more traction. I wanted to advise against it, knowing how bad it will be.
Can we agree to disagree on the definition of a semi slick? I think we agree on everything else :)
bitches! happy birthday you dirty mexican T-bond!
yee yee!
happy 21st birthday tacio!
hopefully the s13 will be there on thursday night bro ;)
Dont think thats gonna happen. He keeps his fling(s) for himself.
ur a dog!
tehe brandon ur a mad dog,
megan loves you i thinkk btw
hey also u keen on a sau sticker or two bro?
Thanks brothers as sisters. luv yall
status on your car duddee??
will she be ready tonight?
wana msg Ray n see if he'll come by?
let me kno if ur car fails and i need to drive you lol
ur a dog!
Oh really? Tell her I love her too.
Do you have the SAUqld one or the Australia ones? I'm actually thinking of getting them or even becoming a member. The Australia ones would look better...
I probably wouldnt be coming tonight unless you guys gonna come over to the southside. Going to Garden City to do some shopping =D
i did - but i ripped them off due to their homo-ness ;)
get my ones :ermm: post in the thread u douche bag
and u better freaking come tonight
or i will kill you :P
I'll yell at you both
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
