what happens when.... ???
FEMALE + 4WD and give them a simple task like a right hand turn.
DUUUUUUUDE!
thats worst then i you described on the phone :|
holy f**k if that was the 32 - id be reading about a mass murderer in toowong who was killing cnuts after a car crashh
OOOHHH TEHRE!
what a f**king stupid broad minded person!
omfg the amount of near misses ive had with stupid ppl at that intersection omgggg
/rant
ps dave looks like that 32 needs to be built a little quicker now
hey guys thought id make a post .... bad timin ey. bad luck champ, lucky u managed 2 block it with ya quarter panel hehe. is all insured ?
Far out, I'd have made that bitch drop her ice cream or something, so is she paying or what?
maybe u should say u were a witness :domokun:
bit of road side panel beating with a lump hammer / jumping on the bonnet, and i got her home.
<snip>
Thats carnage mate!
I had the same treatment to my daily, but about a 10th of the damage.
Those are the days where a daily car pays for itself. :down:
(lol at footy, the ref was pwnt)
Bit of bad luck :)
I nearly had a similar encounter with a female in a 4wd last night at Indooroopilly shops. She started to pull out while I was still going... lots of squealing, lots of smoke... lots of raised middle fingers... If they want to drive bigass cars then they should have to sit a bigass car driving test. I bet 90% would fail. :down:
Hope it's all fixed up soon for you Dave
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
    • My mechanic installed all the parts and then got it tuned which i think is around the corner from him
