tacio is busy at work but he told me his willing to be a mexican seat for a week if it gets done earlier..
my car? well.. shrouded in secrecy i guess :)
who wants to chip in abuy me a personalized plate "WRAITH" i think it will be suited for my application ;)
:) PCE love
anyone got a single 33 rim they want to get rid of? Can swap for skid tyres or pay cash
PS taco man, plates 74CIO are available, you should get them. Unfortunately, TAC10 is gone :cool:
PS taco man, plates 74CIO are available, you should get them. Unfortunately, TAC10 is gone :ninja:
might be able to cut a deal on x2. :)
PS taco man, plates 74CIO are available, you should get them. Unfortunately, TAC10 is gone :D
i might try for BUR1TO
hmm... i might go a 2860rs .64 rear housing running 16-18 psi..
now whats a good choice for ECU.. turns out the tuner i had in mind does not want to touch a nistune :S..
so... know any good tuners? and know any good ECU for SR20.
not really :D. Regardless of what you pick, something better will always come along eventually. It's called progress :D
best bet - pick a tuner, then discuss with the tuner what the best option for ECU is
this sounds juicy :D
cant wait for it to be up. could always try chris @ bob romano performance.
he can tune just about anything. seems that vipec are the flavour atm. how come that tuner wouldnt touch a nistune? get something that does away with afms. have a read on NS, but dont buy PFC, too old / outta date.
Edited by 32_Dave
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
