btw ftw, tbh, BBQ, lol, lerl etc
f/s R32 - Skids great
swaps my bmx, packet of darbs, my unborn son, $1000 caaaaaaaaaaaaaash, and 2 hjs
deal?
ah man the 31 still buggered?
Will be back together tonight, but i cbf bleeding the brakes manually (lines are empty, switched to braided :P), and the air bleeder is at a mate's house miles northside.
So will have to grab that and bleed the brakes on the weekend, then book her in for an alignment. Then happy days :P:)
GTFO!
redsuns got my back on this one
i would love to agree with you but sadly you are not up to scratch with real initial D enthusiasts
If he had another outboard motor he wouldnt of had that problem :)
sadly no i dont want to come off as a prick but sadly i cant tell you :P
but ill tell you boost comes on at 4 :banana: gives me 3 or 4 k to play with depending on how my head is set :banana: oh and its made by garrett? but then again they make heaps ofturbs even for different companies :S
:P
Boost comes on at 4k?????
Wow thats givin away a lot......... ;)
Woooooooooo just found out im getting an extra large tax refund cause work has been takin out to much tax from my pay.
Looks like it might be time to give 6boost a call for myyy turbo, manifold, external gate setup :P
Edited by Danski
Nah not this week man im up at work, will be there the folowing week for suuuuure though.
Rofl @ "they only used old shit cars in that cause they may have fallen off the cliff"
Its about time u piped up micko :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
