btw ftw, tbh, BBQ, lol, lerl etc
f/s R32 - Skids great
swaps my bmx, packet of darbs, my unborn son, $1000 caaaaaaaaaaaaaash, and 2 hjs
deal?
ah man the 31 still buggered?
Will be back together tonight, but i cbf bleeding the brakes manually (lines are empty, switched to braided :P), and the air bleeder is at a mate's house miles northside.
So will have to grab that and bleed the brakes on the weekend, then book her in for an alignment. Then happy days :P:)
GTFO!
redsuns got my back on this one
i would love to agree with you but sadly you are not up to scratch with real initial D enthusiasts
If he had another outboard motor he wouldnt of had that problem :)
sadly no i dont want to come off as a prick but sadly i cant tell you :P
but ill tell you boost comes on at 4 :banana: gives me 3 or 4 k to play with depending on how my head is set :banana: oh and its made by garrett? but then again they make heaps ofturbs even for different companies :S
:P
Boost comes on at 4k?????
Wow thats givin away a lot......... ;)
Woooooooooo just found out im getting an extra large tax refund cause work has been takin out to much tax from my pay.
Looks like it might be time to give 6boost a call for myyy turbo, manifold, external gate setup :P
Edited by Danski
Nah not this week man im up at work, will be there the folowing week for suuuuure though.
Rofl @ "they only used old shit cars in that cause they may have fallen off the cliff"
Its about time u piped up micko :P
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
