btw ftw, tbh, BBQ, lol, lerl etc
f/s R32 - Skids great
swaps my bmx, packet of darbs, my unborn son, $1000 caaaaaaaaaaaaaash, and 2 hjs
deal?
ah man the 31 still buggered?
Will be back together tonight, but i cbf bleeding the brakes manually (lines are empty, switched to braided :P), and the air bleeder is at a mate's house miles northside.
So will have to grab that and bleed the brakes on the weekend, then book her in for an alignment. Then happy days :P:)
GTFO!
redsuns got my back on this one
i would love to agree with you but sadly you are not up to scratch with real initial D enthusiasts
If he had another outboard motor he wouldnt of had that problem :)
sadly no i dont want to come off as a prick but sadly i cant tell you :P
but ill tell you boost comes on at 4 :banana: gives me 3 or 4 k to play with depending on how my head is set :banana: oh and its made by garrett? but then again they make heaps ofturbs even for different companies :S
:P
Boost comes on at 4k?????
Wow thats givin away a lot......... ;)
Woooooooooo just found out im getting an extra large tax refund cause work has been takin out to much tax from my pay.
Looks like it might be time to give 6boost a call for myyy turbo, manifold, external gate setup :P
Edited by Danski
Nah not this week man im up at work, will be there the folowing week for suuuuure though.
Rofl @ "they only used old shit cars in that cause they may have fallen off the cliff"
Its about time u piped up micko :P
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
