now is this referring to the fact that you want to get to bnr, or is this referring to a different kind of ride, due to your carless ass being single?
:( that was gold!
.. john i have a friend named lance;
thats actually his sister, hes always keen for a guy
Just for BnR - as much as i appreciate the offer... ice cream will be the only creamy white stuff entering my mouth, thank you :O
haha nah its an xr6 turbo ute with massive balls lol
No thanks Tris, but I think that PWND guy is keen for it ;) ;) ;)
that blue steel look he is doing is making me tingle in my loins.
Martin - need some spacers :)
The spacers I have don't suit stock wheels (locating ring is bigger to suit advans). The stockers are only on there for a couple of days because she BADLY needs a wheel alignment and i dont want to wear my nice new tyres
Edited by Smity42
just saw a add on tv, some bloke reckons he has cracked the KFC recipe, what a f**khead y would u do that.
Bahhhhhhahahah
f**k some ppl are a waste of fresh air, I wonder what he planes to do with it?
No, if he does it, that's a good thing!
If two stores have the same recipe - UNDERCUTTING! KFC might finally be cheap again!
...f**k now I want KFC. you bastards.
for those of you have have it, add me on msn for christ's sake! life.after.god.isola at motherf**kin gmail dot communists
or myspace http://www.myspace.com/musicbyjohnnystorm
or facebook http://www.facebook.com/johnnystorm6126
I'M BORED!
...now i'm going to go get KFC.
*edit* no KFC for me. Can't find my wallet. Too lazy to have a hardcore search. Rissoles it is!
Edited by Isola
your retarted. kfc is one of the best fast foods known to man, and if the recipe got out, kfc might eventually go broke. :ninja::P:P
ZINGER FTW !!!
ZINGER FTW !!!
who cares if they go broke? if the recipe is out ANYONE can make it so it'll always be available.
it'll never be the same.
hold the spit, its for a cop
meh, so many of the stores are useless and screw it up and make it taste like crap anyway. I used to rake people over the coals in my store when they f**ked up. Ahhh what a shit job managing a KFC was
Martin - need some spacers :P
Dave - how the hell is that going to be on the road on September 1st?
Yeah that looks a fair way from finished
:ninja:
indians have been making fake KFC in the UK since 2001. get with it guys. they've priced it so cheap that KFC doesn't even bother to open stores near the "PFC" stores.
there's probably more PFC's in london than there are KFC's.
nigs in KFC don't sell samosa's with their 3 piece feed, that's why they be broke now.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
