now is this referring to the fact that you want to get to bnr, or is this referring to a different kind of ride, due to your carless ass being single?
:( that was gold!
.. john i have a friend named lance;
thats actually his sister, hes always keen for a guy
Just for BnR - as much as i appreciate the offer... ice cream will be the only creamy white stuff entering my mouth, thank you :O
haha nah its an xr6 turbo ute with massive balls lol
No thanks Tris, but I think that PWND guy is keen for it ;) ;) ;)
that blue steel look he is doing is making me tingle in my loins.
Martin - need some spacers :)
The spacers I have don't suit stock wheels (locating ring is bigger to suit advans). The stockers are only on there for a couple of days because she BADLY needs a wheel alignment and i dont want to wear my nice new tyres
Edited by Smity42
just saw a add on tv, some bloke reckons he has cracked the KFC recipe, what a f**khead y would u do that.
Bahhhhhhahahah
f**k some ppl are a waste of fresh air, I wonder what he planes to do with it?
No, if he does it, that's a good thing!
If two stores have the same recipe - UNDERCUTTING! KFC might finally be cheap again!
...f**k now I want KFC. you bastards.
for those of you have have it, add me on msn for christ's sake! life.after.god.isola at motherf**kin gmail dot communists
or myspace http://www.myspace.com/musicbyjohnnystorm
or facebook http://www.facebook.com/johnnystorm6126
I'M BORED!
...now i'm going to go get KFC.
*edit* no KFC for me. Can't find my wallet. Too lazy to have a hardcore search. Rissoles it is!
Edited by Isola
your retarted. kfc is one of the best fast foods known to man, and if the recipe got out, kfc might eventually go broke. :ninja::P:P
ZINGER FTW !!!
ZINGER FTW !!!
who cares if they go broke? if the recipe is out ANYONE can make it so it'll always be available.
it'll never be the same.
hold the spit, its for a cop
meh, so many of the stores are useless and screw it up and make it taste like crap anyway. I used to rake people over the coals in my store when they f**ked up. Ahhh what a shit job managing a KFC was
Martin - need some spacers :P
Dave - how the hell is that going to be on the road on September 1st?
Yeah that looks a fair way from finished
:ninja:
indians have been making fake KFC in the UK since 2001. get with it guys. they've priced it so cheap that KFC doesn't even bother to open stores near the "PFC" stores.
there's probably more PFC's in london than there are KFC's.
nigs in KFC don't sell samosa's with their 3 piece feed, that's why they be broke now.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
