omfg they do ribs aswell that's pure f**kin genius.
alrighty bed time. wheels are aligned so i'm all set now. will see everyone at bnr tomorrow :ninja:
yo can you mo fos let me know how many stickers you would like each tomorrow,
swing me a pm or tell me on msn or post here
so i bring enuf and everyone is happy :ninja:
also tell me if u want inside or outside ones :P
If you have enough, could I please have two inside ones, and one outside one?
you can have whatever you want,
i cant afford to give them away but :ninja:
i saw your car yesterday martin going down corodrive
i was on the way to montville melany... ooh very noice.
on the way there saw your car along coro drive.. thought to myself who owns a loud pos car that has the same offset as MRR34 ?? :)
then i noticed some bogan driving and i was like.. thats no bogan that d00d is martin!
i resent being called a bogan :mrt:
suspension dood is sick :) can't get rear camber fixed today. Had to go to quickfit for a wheel alignment instead so i can at least put my wheels on
:mrt:
i'm ALWAYS signed in to msn :( . You will soon learn that when i'm signed in and when i'm actually there are two very different things...
it frustrates the f**k outa me
i'm ALWAYS signed in to msn :mrt: . You will soon learn that when i'm signed in and when i'm actually there are two very different things...
yeah, you're now the FOURTH person on my list to do that... thanks heaps :)
tristan... why didn't you add me? :(
So some kids at a set of traffic lights ask me to do a skid, so I did... I felt like I was so at Summernats.
Rock my import Falcon.
Wrecking the Skyline name even more, in a street near you
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
