have u got a dump / front? or u ordering gktech, feel free to borrow mine to see if itll line up, dont see why not.
I've got a dump, just need a front. Is urs a two piece or one piece dump/front. I might borrow it if its 2 piece, otherwise i'm just gonna take it somewhere and get a front made
Tristan bloody murdered that link, I think this is it: Click
thanks breh :thumbsup:
or go the bilstein/king combo. Get PCE to price it up for you or go ERD for the price of SS... I'll rather pay a lil more for SS.
http://www.sauqld.com/ipb/index.php?showtopic=823
The bilstein/king combo will be as good if not better than the Teins.
bilstein > tein
:thumbsup:
dusty car park at work provided a good photo opportunity to demonstrate how much tyre is wasted with 3deg rear camber:
Booked in for wednesday to get it set closer to 1.5deg :D
Nice lol must be killer on tyres
ps COLIN!
I FOUND YOUR DRIFT CAR
lllllliiiiiiiiinnnnnnnnnkkkkkkk
oooh yeeeh
gigity
Yeah. Hang on I need to go and piss on my money tree. Aparently it helps them grow :)
last set lasted 12 months... 6 months of that it was on axle stands :thumbsup:
6months!
you're doing it wrong,
learn to use the left foot, and boot it!
<3
lol I just noticed the awesome new ringpull design on my can of red bull
looks like this (I googled it as I'm too lazy to take a photo):
thats well wikkid, innit. RB POWA
excuse my n00b but wtf is BR?
ps just got back from the guy at archie who does epic wheel alignments,
nicest dude, did my alignment and flip my rears (due to epic cronic badass camberwear)
if anyone needs a wheel alignment or a good chat, shud defs hit him up
:D
however for ball cupping i cant talk PCE Perfomance up enough - they do a top job
thumbs, pinkies, soft/hard, you name it they'l do it
they even provided me with a mexican human seat while i waited outside for my turn, his name was taco or burito or something - lovely young chap
:D
:P
Hahahaha :D
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
