excuse my n00b but wtf is BR?
ps just got back from the guy at archie who does epic wheel alignments,
nicest dude, did my alignment and flip my rears (due to epic cronic badass camberwear)
if anyone needs a wheel alignment or a good chat, shud defs hit him up
:D
BR = Baskin Robbins, n00b
I have also used that guy at archie, and yes, he is a champion. Recommendation second'd
is that roy from bosman tyres?
he's great. did the wheels on the other half's festiva for a bargain price
yeh im gona go see him to, get some tyres for the hypers and the corolla at same time :)
make sure you take advantage of his free wheel alignment
i cant rave about him enough, coolest guy :)
i wana shred my current rubber just to pay him another visit :D
correction, its BnR fool!
sitting on bricks?
thats debateable - as it isnt a dyno king yet, so maybe not powerful enough to get their attention, so it could be..
however it might be in the future - so on the other hand maybe it isnt..
its the choice of whether you would rather the loyalty of someone who is ready to start spending cash on their car vs someone who has already spent their cash, (their car is "finished") - but is willing to put their sticker on the back windscreen..
oops :P
Edited by astrotristan2
Haha you'd like that wouldnt ya :(
Heres some progress pics thanks to Whitey at EFI ;)
with that said,
the car does look delicious dan :)
cant wait to hear her at the next BnR night
:P
nuh-uh. BR dude says otherwise... and so does their website.
i had your back from day one and you dog me. :P
i prefer it when u just lurk and dont post :(
with that said,
:P
Thanks bro but its far from finished, Im hoping to get it back on Monday but more than likely will be ready Tuesday/Wednesday.
I dont really mind as long as its ready for BnR meet on Thursday ;)
Will post more pics up as i get them :(
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
