Regu06? I wanna hear how quiet is that. Hopefully there 1 tomorrow!
man up and be loud brandon
brandon, you will most likely never hear it at this stage :D
zing!
he wants his paint stripped, not you
he know but will do both anyways.
if u both come next Sunday :D , lots of work to be done.
Chassis will be getting primed on Monday 31st if you both come and we all get stuck into it.
Wanna get underneath re-sealed / painted, interior, engine bay done in that week, and rolling ready for the fun stuff. and ill get all the doors, boot, bonnet, guards done over the weekends to come. Im gona aim for motor running by end of September.
estimated completion was end of September @ first, but will be on the road by end of 09. And on track too i hope, so astro save your cents.
If I didn't constantly attract chicks that just stuff me around, I'd know for sure. Grr...
Ahhhh more girl problems.....
So glad I dont have to play that game anymore
his just treating you like a dog cause i raped him good when he questioned me about colours of the day..
tristan: ah dont think you the sky is super la-nce.. err i mean tas
Taz: *gets out giant spoon of the year* broad minded person ur getting no lube!
I wish Tristan treated me half as good as he treats you :)
he just shows his love for u in a different way lol
What a vivid imagination u have there :P
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
