Maybe I should dropby EFI and check your car out when I'm coming back from the coast tomorrow... lolz.
Haha itl be like when someones sick and in hospital and everyone drops in to see how you doin.
You getting your ecu 2moz?
yea d000d!?!?!?!
oh thristian i had the alarm installed today :(
well 3point immobilizer wired to the turbot timer :)
oh helllsss yeh
sounds pornographic
well not anymore.. as tristan will be driving the PCE Performance workshop 180.. :):(
oh so thristan bought goldenwang?
trade his 32 and cash tas's way. cant wait till the swap goes down. :(
Oh so PCE Performance has a workshop now?
if you call sharing, then yes :)
as for energex, get my power back on bitchez... needa work on my car.
sharing? maybe.. i dont want the hassle of spending 40k for a workshop setup..
rather i run my business out of a already established premises then doing dodgies with some bodgy workshop
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
    • Have a chat with the tuner, you'd want to drive the car straight there.
