lolz. Ok. Will keep that in mind the next time. But I'm pretty happy as it is now but we'll see what happens down the track. Thanks for the info.
[Colin]
[/Colin]
stalker lol :D
Good to hear about the tune Brandon. Pretty decent as Josh said sort out your fuel system and get it to hold some decent boost and you will have a very capable car :D
@super coach tristan: tried a new grip tonight and got 51 with a strike rate of ~210 :)
Also got about 2 dozen stumpings and catches behind the stumps and a few wickets bowling. Good night (y)
very impressed indeed
i didnt realise u were a keeper though - i figured with ur height u were a fast bowler :D
By very good tune I mean someone like Matty Spray..
My rb/S13 with 600rwhp was tuned by Matty.
:D
man I shoulda sampled some of thristan's female friend's muff while I was still in brissy. that brunette with the tig ol bitty's was nice.
which one was that breh?
hmm...
should i get kazama or KTS for suspension arms... hmmm..
triple 9? :)
Dave ya fat slapper, been doing job shit all morning. Gimme a call if you get this, or I'll give you a buzz when i've finished up
epic cupping - rough day nismoh
2x phone interviews this morning, another one tomorrow and had an inperson interview yesterday that went from 2pm - 5pm.
Pretty sure these jokers should just pay me the big bux and not question me.
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
