lolz. Ok. Will keep that in mind the next time. But I'm pretty happy as it is now but we'll see what happens down the track. Thanks for the info.
[Colin]
[/Colin]
stalker lol :D
Good to hear about the tune Brandon. Pretty decent as Josh said sort out your fuel system and get it to hold some decent boost and you will have a very capable car :D
@super coach tristan: tried a new grip tonight and got 51 with a strike rate of ~210 :)
Also got about 2 dozen stumpings and catches behind the stumps and a few wickets bowling. Good night (y)
very impressed indeed
i didnt realise u were a keeper though - i figured with ur height u were a fast bowler :D
By very good tune I mean someone like Matty Spray..
My rb/S13 with 600rwhp was tuned by Matty.
:D
man I shoulda sampled some of thristan's female friend's muff while I was still in brissy. that brunette with the tig ol bitty's was nice.
which one was that breh?
hmm...
should i get kazama or KTS for suspension arms... hmmm..
triple 9? :)
Dave ya fat slapper, been doing job shit all morning. Gimme a call if you get this, or I'll give you a buzz when i've finished up
epic cupping - rough day nismoh
2x phone interviews this morning, another one tomorrow and had an inperson interview yesterday that went from 2pm - 5pm.
Pretty sure these jokers should just pay me the big bux and not question me.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
