pics of it with the xd9s on it shan?
nah, just sittin upstairs in the shop for now lookin pretty. waitin on tas to get back to me on prices for Dmax 30mm flared fenders.
f**k yehhh, thatll b sexy as, i think tas is currently in talks with the jap dmax :)
woooooooooo
got some random mish mash of colours tho... i wanna get em powdercoated white. they don't make em in 10" +12 any more :)
Dave's underbody is almost as sexy as his underbody *wink wink*
hahah. thanks for all the help man. okay UPDATE bitchezzz thanks to some hard work from josh, we accomplished this finally today.
prepping for etch primer:
after etch:
and just managed to do a test run of my seam sealing skills, before calling it a day.
hope it don't rain tomorrow, start work on the engine bay :D plus ill post up a pick when i pickup my rims from getting christened with its first set of rubber.
Managed to get it to stay on its side did ya?
yeah that drum is holding it on its side, it was scary unbolting the front support to paint.
Looks good! Maybe you should take a full month off work to finish it!
a month, thats the total im aloud in a hole year. :down: have to wait till after chrissy i get 3 weeks.
Rains are comming Dave, starting to spit at my shack.
why did i just think of you eating corn and yelling out "ma ma the rains r here"
umm looks pretty scary outside, ive covered her all up. hope the plastic dont leak :D
and i just got a surprise from a nock on the door.
TADA !!!
anyone wanna buy a gtr for gtst front bar - CALLING TAS !!!
Becuase, deep down I am kinda bogan?
If Taz buy's that bar I will buy the type M bar ^_^
Saves me painting my black type M one.
John, PM me your mobile number so I can make the promised phone call tomorrow night
aiight... but if you throw off my :( rhythm... so help me... :D
Edited by Isola
what front bar are u usin dave? or did u buy that gtr shell?
gtr for gtst. havent looked at the shell, has come at the wrong time. ill probably ring the dude end of year see if hes till go it.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
