dont efi believe in oil caps?
tas - i could be interested in *vertex style*, post up or email me the possible price and colours :P
Edited by astrotristan2
Take mine there anyway, until my warranty runs out anyway. Dan is pretty good. I get the full going over every time the car is in there and hes picked up a few minor leaks and stuff that I wouldn't of seen. With a labour free brake flush aswell that looks to be good value.
blasphamy brandon! :(
this is the mother site! *salute!*
yea ill try and get some pics..
colours are the fluro ones u saw in the option mag..
PCE is the way of the future..regardless of what car you have....no one could ever doubt the real quality and honesty of the work they produce there.. Astrotristian is my witness
Thristian: Bought 11ty billion T25*SR* T3*RB* turbo to manifold gaskets today.. much much better quality then i expected :)
Edited by Redsuns88
Better not get one through tas then :(
your just upset i dont want anything to do with classic antiques
where is ur avatar pic colin!? :)
Edited by Redsuns88
where is ur avatar pic colin!? :(
Good question lol. No idea where its gone.
I think that's a compliment ;) Most people just call it an old piece of sh*t :(
Rolling shell? Whats included? If all it needs is a motor n gearbox i could deal with that :)
Whats included? A shell. Might even find some doors still on it :). It's currently rolling, if you count 4x steelies (no tyres) on the chassis rails that it can roll back and forward on
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
