Yeah I've got a job with them for life if I want it basically. There are Directors and other upper management people that all started where I am now which is encouraging. I won't graduate till 2012 so still a way to go with uni yet.
Vac Student = Vacation Student? like work experience kind of thing?
I work full time for them so its not really like the work experience thing.
you wouldn't be suprised with what I can do on a webcam...
I know you :blush:
I wouldn't be surprised with anything you do lol
What are you looking at doing now?
Pretty much. But the good vac students we have are sorta like part times too. They'll come in whenever they dont have uni.
Thats cool. Nice to know everyone in the company and thats 1 of the reasons why I'm with mine now.
It actually has some theory behind the madness. Technically to dabble in my own developments without paying too much outsourcing for people to oversee things, you need or need certain aspects of a builder’s license.
I am looking at working for someone who can offer a trade, which is a % towards a builder’s license. However the position isn’t an apprenticeship or anything.
Essentially I’m more of less looking at ways of bypassing certain parts of uni if I was to do a degree in property development and or dabble in my own ventures by making it easier.
I'm kinda shifty.. But it's legit and done often.
im going to post this in the "ideas/bugs" section
we need instead of advatars we need webcam!
*drool
why do I get the feeling you would look at mine pretty often
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
