Dear Dave,
seen it mate, got photos of it sliding to, but i'll raise by not 1 but 2
^^^ this is my inspiration to my next 32
and as for that fuel pump i got a $10 solution for ya in my pile.
haha yeh I saw his drift pics.
I'd buy it, even just as a tester, but I cannot get out to get it. My car is garage bound, end of my street and it dies. I can get to toowong shopping centre by city cat, about as far as I can go
i could bring the pump somewhere and meet you? try get as far as you can with ur 32 and we'll replace the pump on the side of the road LOL.
:thanks:
Too broken haha. Let me know when your finish work and i'll see if there is a city cat running to toowong
Hey Colin,
You know how you hate me and stuff? Well... I just went to McDonalds... and wound up having the counter girl for dessert :worship::(
You picked up at Maccas.....wow..
Maccas...
If it was Hungry Jacks, then hi 5 time, but Maccas. :worship:
+1
The chick on the drive through at HJs was a stunner. No desert for me though :yes:
Thats because you drive a skyline, if you had a commy with fully sick chrome wheels and 15 subwoofers then she would have been out the window like a flash.
*sigh*
T88 install update:
- Fuel filter looked fine
- There is some grit in the tank, not enough to warrant pulling the tank out
- Fuel pump is the original item still had all factory seals
The pump filter that sits in the thank is brown and had gritty alloy looking rubbish on it (I assume from the alloy nozzles at fuel stations. I'm hoping it's just a case of a 20 year old pump :yes:
Now taking bets I might have f**ked something
- Standard one way valve after the fuel filter, before the injectors perhaps?
Dave:
As far as I know my car still has the AUTO ecu, do you have one of your manual ones you can check the numbers on?? I have no idea what numbers you need (if you know let me know and i'll get my ones).
If i do indeed still have the auto one.. I'll take one of those manual puppies too
looks like you found me... good start.
friends suggestions for everyone else sent to you.
I don't have any bloody pics! Nice little 18 year old emo bitch. Fun times.
No pics, it didnt happen
yeah i found most of you from the BR page :yes:
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
