matey as i said before.. slip me some cash and i will do the independant inspection for you.. im sure we can work out something!!
Will do :( - if it's still around, there's a turbo auto s13 in hamilton that looks ok. Hopefully get that and do a manual conversion. If not, I'll try and find a decent s13 that we can throw an RB into. Or who knows? There may be a tidy 180 available, or a 32... time will tell!
Wait till Thursday when youve got 300rwkw of RB muscle under your ass :cool:
Wooooooooo
lol
You BETTER be taking me for a spin when you come to Baskins! I'll even take the risk of losing my seat for that!
you ever... ever.... EVER link me to a Holden again... and I'll link your nuts to extinction buddy boy :yes:
I'm gonna have to bail on tonight also
I'd make the effort if i had a car to drive, but CBF for passenger
*raises pinky*
Colin, dibs on your passenger seat?
btw - need the info for tonight -where am I meeting you guys? should I just meet you at your house tas and ride backseat till we meet up with Colin?
Can only see the glow worms at 3am that's why it's so late. Wouldn't wanna go all the way through springbrook and miss the glow worms :cool:
If you thinking about a good drive down that way, I know a good way. Then morning I passed you on Calagribar road, I was just coming back from an epic drive. PM if you want this information, though I may not give it to you and make you wait until next weekend.
WOW JOHN WTF?!
*shrug* apparently when there's a little green 'woo already on the roundabout, and approaching you... you enter the roundabout... I must have cut class that day in driver's ed...
how are all your injuries going
*cough*compensation*cough*
haha CBF to be honest hey. I taught her how to use a roundabout. she'll never do it again. crazy kiwi's.
oh, her car is two weeks old ROFL!!
tas - you can put a PCE sticker on whatever I buy :D
Geoff - I missed that post before. Good to hear man, congrats!
does anyone know what wheels are on this boat? I like 'em... and want a set. Hektik rims bro!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
