I saw Nankangs being posted and had to laugh.
*laughs*
Car has not been complied yet.. so nangas is what was in japan..
Federal Evo's is what it will be wrapped in when i finish it :)
anyways broad minded persons.. i won mobile 1 guys over..
PCE Performance/Phantom Motors are now backed by Mobil 1 !
hey dan, yes r33s cop shit lol,
but if i were to have one and had a dickload of cash, itd look like this:
YUMMEH!
Edited by astrotristan2
my orange is so teh sex
ur just upset that i can pull 10ton bitches while ur car sits on bricks with rust :D more rust then dave!
Fixed.
I think you might have been lead down the garden path there with the size/quantity thing Tas
Tas pulling chicks:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
