oh buenos dias!
I am sure that joke (Rob schneider the stapler) is from south park, robot chicken, or something else along those lines. I've def seen it before.
Edited by Smity42
willing to donate a 80mm f**ked holesaw for speedholes..
on conditions that i choose where..
was thinking infront of the driver windscreen.. radiator to catch more all flow and better cooling
rocker cover to help with installation of oil catch can..
exhaust- helps with releasing gasses faster ey!
brake rotors - to help cooling
roof - helps with less drag and more free flowing air into cabin
out of ideas atm to help improve the woo
Engine oil bypass kit would improve the Woo dramatically. Imagine how dirty the engine is getting with all that oil flowing through it.
Just to let you all know
PCE Performance- Is now the newest Queensland dealer for TRUST/GREDDY
Buy with confidence, Purchase from PCE Performance
place your orders now..
Greddy Touch are nearly landed
TRUST cooler kits
Metal headgaskets
omg jiizzzzz!
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
