im in my own personal recession -
i need this cheque to hurry the f**k up and go thru so i cant pick up the 180
i think i want 17*9.5 +15 black driftdeks
WTF the bank doing? Talk about efficiency.
yeeh i kno hey
i used the "not acceptable line"
got put thru to 2 different bank managers, and guess waht? my funds have now cleared :cool::)
Edited by astrotristan2
Josh we started a fight club at the car wash but obviously Brandon wasn't listening to the rules. Rule 1: You don't talk about fight club!
DONE! Now stop asking me
Else
WSname = ActiveCell.Value
Set wsheet = Worksheets(WSname)
If wsheet Is Nothing Then
Set TemplateSheet = Worksheets("Template")
TemplateSheet.Copy after:=Sheets(1)
ActiveSheet.Name = WSname
ActiveSheet.Range("C3").Value = WSname
ActiveSheet.Range("C4").Value = ""
Call CopyData
Else
Call CopyData
End If
Anyone can solve this for me?
WSname = ActiveCell.Value ====> this shit works
Set wsheet = Worksheets(WSname) ====> but this doesnt.
Apparently it doesnt work because that sheet doesnt exist. Maybe I can use this error (on error goto) to skip to the next step which I want to do??
I'm trying to check if the sheet exist or not. And ths sheet that I'm check is variable.
I might come, one day. Maybe. Haha
Else
Call CopyData
Else
Call CopyData
End If
x zero.
Brandon, does it not work all the time, or only not work if the sheet doesnt exist?
The on error goto WORKED! That bit on Set wsheet = Worksheets(WSname), only work if the sheet exist. So I dont know how the f**k you're suppose to check a variable sheetname. It'll only work if you wanna check a pre-specified sheetname.
Now I've got another problem of making the sheet active again because of that. This macro shit is fun and time flies when you're troubleshooting
No ice creams from me. Micks' a champ for fixing that Evo up.
Lol lobster back piping ftw?
Bring it on Joshy. No hair pulling or scratchin though :cool:
x zero.
I believe its /zero.
excel macros are sh!t coz they are still based on VB6 which came out about when i was in primary school :S
programming languages have come so far since then but macros are still stuck in the stone ages
to make the sheet active wsheet.activate() or something like that should do it.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
