I was already in the city today.
Fark you.
Lucky I live like 5kms away :cool:
You still there? Want to eat some diseased chicken with me?
city where? where the hell am i supposed to park? where'd you park?
I park at Kangaroo point and walk over lol.
John. City at like 2:30 ish?
I hate you guys, I'm at work :cool:
Its epic as, hit some up!!
Next time for sure
City cat.. Oh thats right, your "inland" :D
Bus? train surely there is some pubic transport out that way? If not just park it in a loading zone and tell them you work for the secret service.
Only if the rabbit can come?
Normally I have a rule about animals in my pants but that rabbit looks like it knows how to have a good time :cool:
Im back at home.
But the city cat stops down there >>>
Where are you eating? I'll have to walk down to the jetty in a sec
Im back at home.
KFC in queen street or something like that.
just to let you know the R32 is currently on its way to my workshop
haHAHAHAHAHAH
HAHAHAH i can not contain my self
i have just jizzed everywhere while waiting for it!!
I don't blame you - i would have to! Can I come and see it tomorrow please?
Well why don't we go to kangaroo point kfc then?!?!?!? I'll pick josh up
sneak out!
my police encounters are bad enough without trying to add that to it!
The city is better. It has bitches and people that look like Tristian
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
