not going to register my car today..
tomomorrow!!!
going major service and time belt today!!
other deliciuos parts going in tommorrow
Hey Tas did you end up finding out if Federal make a street legal semi slick?
I'd say yes
http://www.skylinesaustralia.com/forums/Fe...es-t271212.html
However, they sorta look more like a uber soft street tire, apposed to like Advan A048's and Toyo R888's etc
I'd say yes
Thanks Josh ;)
Have to try chase tas up and see if he can get these in a 19"
Hmmmm I wonder how much the 265/30ZR19 are
Ring around 5 different shops and get 5 different price's.
My price for 16/205's are anything from around $350 - $400ea
Josh seeing as though your such a fountain of knowledge today . . . IYO whats the best place to get a 3"cat (doesnt matter about highflow as im just gona gut it anyways) and a set of adjustable camber arms for the rear of the 34?
Ahh stuff that I think ill stick wit the federals, they waaaay cheaper :D
PCE!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
