not going to register my car today..
tomomorrow!!!
going major service and time belt today!!
other deliciuos parts going in tommorrow
Hey Tas did you end up finding out if Federal make a street legal semi slick?
I'd say yes
http://www.skylinesaustralia.com/forums/Fe...es-t271212.html
However, they sorta look more like a uber soft street tire, apposed to like Advan A048's and Toyo R888's etc
I'd say yes
Thanks Josh ;)
Have to try chase tas up and see if he can get these in a 19"
Hmmmm I wonder how much the 265/30ZR19 are
Ring around 5 different shops and get 5 different price's.
My price for 16/205's are anything from around $350 - $400ea
Josh seeing as though your such a fountain of knowledge today . . . IYO whats the best place to get a 3"cat (doesnt matter about highflow as im just gona gut it anyways) and a set of adjustable camber arms for the rear of the 34?
Ahh stuff that I think ill stick wit the federals, they waaaay cheaper :D
PCE!
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
