just got back from sd drift day
f**king so sweet,
and it hurts me to say it - but r33s go pretty sweet once their suspension is stiffened up,
kevin took me for a spin and it was sexy :D
*flamesuit on*
I loved my old r33 series 2. kinda regret selling it.
Waaaaahhooooooooo
Just got of the phone to efi, my car just made 350rwhp on 12psi and making full boost at 3800rpm :(
They going to resume tuning later tonight and crank it up to 18psi
YAY its all coming together :D
timing belts suck. try working on alfa V6's had to do a timing belt and water pump on one again today. 8 hours work solid, no timing marks to line it up with.
so they get the alignment right martin?
grats mate..
good to see your tune turned out like brandons
100kw short
Hmmm maybe you didnt read it properly
I said they would resume tuning tonight and crank it to 18psi which will more than likely exceed our expectations of 300rwkw
grats dan. 350hp on 12 psi is a good number. More boost!
Yeah man they are crankin it up to 18psi tonight.
Ill post up the final figures when they call me soon :P
Very nice. You will definately hit that target of yours at 18psi. Mines at 16psi and doing 340awhp which potential fuel problem and restriction. With your build you shouldnt have any of those problems I see.
Yeah bro, schmick as. I love a good alignment :P
Old mate with the tats did it. He remembered it from last time he did it and set it up the same :)
:P
I casually sit by and have a read of these forums, don't say much, and everyone seems pretty cool. But far out, Redsuns88 , you come across like the biggest tosser hey...constant sarcastic demoralising shit is what I read from you here. It's possible I'm massively misinterpreting a lot of what you post, it's just an observation I've made over quite a long period of time. Are you as much of a smart ass tool at the BR meets as you are on here ?
LOL JVL... anytime u want to talk face to face mate.. you know where to find me on a thursday
and yes i think your a tool too..
did it take you long to post that up?
judging by your awesomeness constant serial pikings on coming to the meets made yourself look like nub..
surprisingly i find it amusing you say you want to come but you never did...yet your just one of those keyboard warriors..
RWARR!!~
Hello kidz.
Just to fill you all in, Dans 34 was today making 351hp on only 12psi, this combo we have done on another RB25 neo but in a R32 and was making 366hp on 15psi so dans was a great surprise on such low boost.
With the setup "6Boost kit with GT35r .82 rear" its seeing full boost at around 3800rpm, its making 280hp @ 4400rpm which is amazing.
We left the tuning till later tonite (due to cooler air) but came across a big boost leak from those big T-clamps on the intercooler and removed from the dyno to be fixed.
Back on the dyno first thing to tune away at 18-20psi where im sure it will see 400hp if not more on pump fuel.
Keep in mind this engine is a STOCK RB25 neo with NO cams.
Will keep you all posted and dan can upload you all the video when done.
Cheers Whitey @ EFI
mate shut the f**k up. anything u wana say to redsuns in that manner i take offence to also.
and while im in a shit mood due to your "crap"
Hello kidz.
Cheers Whitey @ EFI
way to take 7 + weeks, judt don't un-do it by blowing it on the dyno. dont like me? take it up with JVL87
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
