just got back from sd drift day
f**king so sweet,
and it hurts me to say it - but r33s go pretty sweet once their suspension is stiffened up,
kevin took me for a spin and it was sexy :D
*flamesuit on*
I loved my old r33 series 2. kinda regret selling it.
Waaaaahhooooooooo
Just got of the phone to efi, my car just made 350rwhp on 12psi and making full boost at 3800rpm :(
They going to resume tuning later tonight and crank it up to 18psi
YAY its all coming together :D
timing belts suck. try working on alfa V6's had to do a timing belt and water pump on one again today. 8 hours work solid, no timing marks to line it up with.
so they get the alignment right martin?
grats mate..
good to see your tune turned out like brandons
100kw short
Hmmm maybe you didnt read it properly
I said they would resume tuning tonight and crank it to 18psi which will more than likely exceed our expectations of 300rwkw
grats dan. 350hp on 12 psi is a good number. More boost!
Yeah man they are crankin it up to 18psi tonight.
Ill post up the final figures when they call me soon :P
Very nice. You will definately hit that target of yours at 18psi. Mines at 16psi and doing 340awhp which potential fuel problem and restriction. With your build you shouldnt have any of those problems I see.
Yeah bro, schmick as. I love a good alignment :P
Old mate with the tats did it. He remembered it from last time he did it and set it up the same :)
:P
I casually sit by and have a read of these forums, don't say much, and everyone seems pretty cool. But far out, Redsuns88 , you come across like the biggest tosser hey...constant sarcastic demoralising shit is what I read from you here. It's possible I'm massively misinterpreting a lot of what you post, it's just an observation I've made over quite a long period of time. Are you as much of a smart ass tool at the BR meets as you are on here ?
LOL JVL... anytime u want to talk face to face mate.. you know where to find me on a thursday
and yes i think your a tool too..
did it take you long to post that up?
judging by your awesomeness constant serial pikings on coming to the meets made yourself look like nub..
surprisingly i find it amusing you say you want to come but you never did...yet your just one of those keyboard warriors..
RWARR!!~
Hello kidz.
Just to fill you all in, Dans 34 was today making 351hp on only 12psi, this combo we have done on another RB25 neo but in a R32 and was making 366hp on 15psi so dans was a great surprise on such low boost.
With the setup "6Boost kit with GT35r .82 rear" its seeing full boost at around 3800rpm, its making 280hp @ 4400rpm which is amazing.
We left the tuning till later tonite (due to cooler air) but came across a big boost leak from those big T-clamps on the intercooler and removed from the dyno to be fixed.
Back on the dyno first thing to tune away at 18-20psi where im sure it will see 400hp if not more on pump fuel.
Keep in mind this engine is a STOCK RB25 neo with NO cams.
Will keep you all posted and dan can upload you all the video when done.
Cheers Whitey @ EFI
mate shut the f**k up. anything u wana say to redsuns in that manner i take offence to also.
and while im in a shit mood due to your "crap"
Hello kidz.
Cheers Whitey @ EFI
way to take 7 + weeks, judt don't un-do it by blowing it on the dyno. dont like me? take it up with JVL87
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
