sorry all to burst your little bubbles..
After i got off the phone with shan i called around and pulled a few strings..
the car was done in japan.. and not shans..there isnt any one in brisbane that can line up this kit so perfectly.car was complied not long ago..
and picked up at the docks.. .tristan can confirm this..
sorry matey :cool:
Why do you ask my old friend ?
edit - VDO seimens 650cc
ive just been doing a lot of reading on injectors to power, so i was just curious :mad:
im tossing up between 550 and 740's for the 180, but yeh idk, just trying to do as much reading as i can :)
im sure if nismoh had his way he'd want everyone to run 1000cc :cool:
- not taking a jab at you or efi lol :(
sorry matey :cool:
yep i can,
car came in from jap, went from the docks to compliance, and arrived at phantom motors with trade plates -
it was then given a rwc and put on the road
its a fresh import
big red has either the same or similar bn wide body kit
and big red was the one shan and his workshop (j-spec?) built
youre gonna put it in ? ive got some super glue to glue it in if u need 2 borrow it :)
rofl your jokes are lame like your car :( prolly find that at bell st maccers too in VIC :mad:
yes micko i went there :)
did a supra conversion lately.. we got two Rb26 conversions happening in the next 2 weeks
so mine will be piece of piss.. but before it in.. got a few things to do too it! :cool:
whats the plan tonight for everyone?
Yes there is. I can write you a list, in saying this the work they do and the cars they work on would mean you wouldn't walk out under $20k.
ive just been doing a lot of reading on injectors to power, so i was just curious :)
Haha nah man all good just wondering what you were up to (had the suspicion you might be buying some goodies) :mad:
lol is that the best u can do ;P
Haha nah man all good just wondering what you were up to (had the suspicion you might be buying some goodies) :cool:
just need to rob a bank ugh :(
yes micko for you ill do you lightly :cool:
what just happened ? (refers to dans reply). u are gonna have to justify "lame" my friend. and i only went to noble park maccas, it was shit !!
remember thristan dirty SR is only a 4 banger so will need about 50% more injector for the same power
Edit: Though danskis probably aren't anywhere near maxed out yet anyway
Edited by Smity42
True :cool: I believe they will be at about 80% when im running 420hp
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
