52mm alloy dual core rad has arrived with new piping!
cbf putting it in.. might way for it to either shit itself or new engine transplant..
looks huge.. i dont think there will be much clearance or fk all actually for clutch fan and shroud
So you're the one trying to get rid of the radiator...
I'm looking at getting the 40mm one from justjap.
BAHAHAHAHAHAHAHAHAHA just went out to test out the Bee*R flatshifting mode.
Got literally 10m from my driveway and saw a cop car in the driveway of the golf course
so, quickly turned it off, did a lap of the block, and went back in to the garage. Sirens on, cop comes up for RBT.
All good, blew 0. She was actually quite nice, had a bit of a chat. To be fair I would have looked really suspicious :). Might stay out of trouble for the rest of the night...
f**k you and your good luck martin. if that was me i'd be arrested for sure.
Thats because you would have:
Dan says:
should have just shut [the garage] and run out the back door
i think i would be the heaviest out of the thursday crew, with a lazy 115kg
somebody is welcome to prove me wrong
encouraged even
i heard dave was writing you off, saying he weighs more, you aint shit and packs a meaner punch...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
