yea bring the tank any time/
edit: thought u was talking about your 'woo for a split second
ROFLCAKES! no way! you guys don't need that f*cker down there blowin' smoke all up in your shit! :merli:
I'll see if I can find some pants... put them on, and then bring it down. Coffee too?
Just finished work.
Started at 8am yesterday.
How was the meet. Bummed I missed out on this one, as it looked like it was going to be a decent turnout
ps. out at the chalk on Sunday arvo around 4pm if anybody is keen.
Just finished work.
You didn't miss anything this week buddy, was a pretty poor turnout intelligence wise. Was good once it was back to the regular crew + a few other smart kids though :merli:
Now, go get some sleeeeeeep!!!
lol
will have to make the next one to catch up on the goss. or you farkers can drag your asses out to the chalk on sunday and have a few cheap beers.
there is stand up comedy on as well..
NO SWAPS NOW - HAVE ANOTHER CAR
MONEY SALE ONLY
Have just done:
- New timming belt
- New timming belt bearings
- New/Replacement CAS
- Replacement radiator
- Replacement fuel pump (still have old one here in box)
- re-installed standard clutch fan and shroud
- New plugs, oil, etc
All work done by ERD except the plugs, oil change and replacement pump. This car now has ZERO maintenance for it's new owner, car also now has full 6 months rego.
No swaps.
$6850ono
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
