So whats everyone up to tonight??
race f**king mustangs?
probs to a fully rad nebo run, followed up by a huge bake and skids in yatla/stapyton, followed up by highspeed highway run, a POWERSHIFT, then going to drive thru the valley, rev teh shit outa my vtec at everyone that rocks up next to me, maybe go to milton macas and start up my subs and pop my bonnet, then finish up at asply hyperdome
WHAT A NIGHT PLANNED AHEAD
time to make ur appearance now!! :D
i dont know a new member just reading having fun... touchin bits?
his hands were busy, they are free now - and i feel like a smoke and rolling over and going to sleep
Don't forget to stop by 'that workshop' and drop 2nd in their carpark
Sounds Fulli Hecktic
NFI eh. Maybe his tractor got stuck in a field somewhere? Alright nigs I gotta stop wasting time now. Back into work lol. Laters
yeh probs about time i get ready for uni
holla bishes
the lack of tractor love around here hurts my feelings, I love working on Annas car, for a home mechanic rb26dett fails badly in comparison...actually for street driving it does too, feeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeel the lag
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
