plol hahaha
so i just finished creating a dream list of parts..
all mainly Mines..
and then i saw.. the price of them rebuilding your engine..
about 23k + freight..
Edited by Redsuns88
23k for a 26?? Sure the mines car is responsive, but i know a better way to get response for that sort of money.....OS Giken RB30 :whistling:
Ive pretty much got my dream list, all i need is an assembled bottom end and decent brakes!
plol hahaha
all mainly Mines..
Depends on what you get for that 23k. If thats for a crate motor all ready to go incl ancillaries(spelling?) then its not too bad.
Giken 30 you pay 23k just for the short block! Whats the specs on yours?
oh and newer suspension, its ok but it looks like its very old
Bilstein Kit from Dan is good :thumbsup:
plol hahaha
all mainly Mines..
Just reread that and saw that word lol. Again it depends on what you get in one of their rebuilds but 23k is f**king exxy.
its got the head too with cams of your choosing it was 26k last time i checked for that, but that was delivered.
General specs are
HKS 2510s that were slightly highflowed upon rebuilding so are rated at about 325hp each instead of 310
Ported Head
Tomei Poncams so whats that 260 somthing degrees and 10mm of lift? somthing like that anyway
Power FC (Want to change that to the new adaptronic super ECU)
Z32 AFMs
Sard 750cc injectors in a Sard fuel rail with a sard FPR and some big intank pump
Trust dumps and front pipes into some random 3.5 inch exhaust
ARC intercooler
Profec B spec 2
Apexi intake piping and pods
NPC Twinplate
Rebuilt Gearbox
Rebuilt 4wd system
Rebuilt drive shafts
19row oil cooler
Oil mods to the head, restrictors drain at the back of the head ect
Baffled sump
Currently being done
Rebuild including:
ACL pistons
Spool rods
and new billett oil pump gears designed by shrek and ranga
external fuel pump and surge tank
I think thats about it
Tis a very nice list :D
omg colin since when do you design stuff? :whistling:
:thumbsup: I don't. Not oil pump gears anyway. That be Shanef :D
i have literally deflated my left nut over this..
and my right one
tomei?
FK this, I wanted to add my even sexier dump pipes but i can only fast reply as the frigging normal buttons dont show up on the f**king computer for some reason! :whistling:
nope work computer, im betting that the image for the button is hosted somwhere that is blocked auotomaticly, lots of threads have no pics on this comp too, but not a notification that its blocked jest a big area of nothing
I feel ya pain, I get heaps of plank spaces on my work pc too :whistling:
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
