plol hahaha
so i just finished creating a dream list of parts..
all mainly Mines..
and then i saw.. the price of them rebuilding your engine..
about 23k + freight..
Edited by Redsuns88
23k for a 26?? Sure the mines car is responsive, but i know a better way to get response for that sort of money.....OS Giken RB30 :whistling:
Ive pretty much got my dream list, all i need is an assembled bottom end and decent brakes!
plol hahaha
all mainly Mines..
Depends on what you get for that 23k. If thats for a crate motor all ready to go incl ancillaries(spelling?) then its not too bad.
Giken 30 you pay 23k just for the short block! Whats the specs on yours?
oh and newer suspension, its ok but it looks like its very old
Bilstein Kit from Dan is good :thumbsup:
plol hahaha
all mainly Mines..
Just reread that and saw that word lol. Again it depends on what you get in one of their rebuilds but 23k is f**king exxy.
its got the head too with cams of your choosing it was 26k last time i checked for that, but that was delivered.
General specs are
HKS 2510s that were slightly highflowed upon rebuilding so are rated at about 325hp each instead of 310
Ported Head
Tomei Poncams so whats that 260 somthing degrees and 10mm of lift? somthing like that anyway
Power FC (Want to change that to the new adaptronic super ECU)
Z32 AFMs
Sard 750cc injectors in a Sard fuel rail with a sard FPR and some big intank pump
Trust dumps and front pipes into some random 3.5 inch exhaust
ARC intercooler
Profec B spec 2
Apexi intake piping and pods
NPC Twinplate
Rebuilt Gearbox
Rebuilt 4wd system
Rebuilt drive shafts
19row oil cooler
Oil mods to the head, restrictors drain at the back of the head ect
Baffled sump
Currently being done
Rebuild including:
ACL pistons
Spool rods
and new billett oil pump gears designed by shrek and ranga
external fuel pump and surge tank
I think thats about it
Tis a very nice list :D
omg colin since when do you design stuff? :whistling:
:thumbsup: I don't. Not oil pump gears anyway. That be Shanef :D
i have literally deflated my left nut over this..
and my right one
tomei?
FK this, I wanted to add my even sexier dump pipes but i can only fast reply as the frigging normal buttons dont show up on the f**king computer for some reason! :whistling:
nope work computer, im betting that the image for the button is hosted somwhere that is blocked auotomaticly, lots of threads have no pics on this comp too, but not a notification that its blocked jest a big area of nothing
I feel ya pain, I get heaps of plank spaces on my work pc too :whistling:
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
