John: its the actual tyre being noisy and not from lost of traction etc. Generally better gripping tyres are noiser than lesser gripping ones. And thats why I'm checking whats the best compromise between them.
Yep, I know. Was making a remark about how quiet/unnoticeable the tyres were, until they squealed. Other than that, we didn't hear tyre noise. Had the windows down too for the most part.
he actually knows that but he was commenting on it.. generally the 595 are quiet depending...
*nods*
is it a 300kw beetle?
I see what you did there :P
Thats the exact reason why I'm asking. I cbf about the noise on mine as the exhaust will be louder but on her beetle its different. The CR KAI I sold to my friend had some ling longs on them (cheapass) and I didnt know they're noisy until he put them on his cefiro. Its very annoying to hear thats for sure, sounds like bee buzzing.
Yeah come for a drive in mine. My car is very quiet when not getting up it so you would notice the tyre noise if there was anything noticeable. There just isnt. They are just a very competent tyre that do everything you ask of them.
Yea will do. You guys still doing the wash or what?
John: Got ERD to check the loading and speed stuff for 535.
Dave: I called him first but was disappointed with the price he quoted for KU31 (and other models too). Maybe he can offer a better price if you rock up but I highly doubt. The price difference between him and option1 is more than 100bucks for all 4 fitted and aligned.
No one can beat Option1 if they still want to make money on the tires.
They sell them the cheapest to sell more.
Like you always say, the best deal will get your business.
tight ass talk imo!
you can better business deals if you continue to buy from one place and always make it clear..
otherwise u will forever be running around looking for the best deals.
edit0- how much are they charging u a tyre?
Edited by Redsuns88
Question Guys!
I need some help with tyres here. Wife's new beetle gonna be here next month and she's getting 17s for the car, so obviously she'll need tyres. What would you recommend?
Model Noise Wear Price Grip TOTAL
RE001 2 2 1 2 7
KU31 3 3 3 2 11
KU36 2 1 2 3 8
595 SS 3 3 3 2 11
595 Evo 2 2 2 3 9
Size that I'm getting is 215/45/17 and judging from the price I've got here, KU31 (option1, cheapest) and SS (ERD, cheapest) are the best compromise between noise/price/wear. What are your thoughts?
KU31s or 595 evo. I have the KU31s on mine and they are extrememly good for the price.
Get the SS. I've got no complaints on mine. Brilliant everyday tyre.
I've driven on both the SS and KU31, the KU31 is much grippier. Can't comment on noise as I don't hear them over all the other rattles my car makes, or tyre wear as I haven't had the KU31s for long, but I'm much happier with the KU31 than the 595SS.
595 evos are meant to be better than the SS though.
Brandon... I'd recommend Linglongs.
LINGLONGS FTW!
+1 :)
535s are sh*t. don't even bother
Edited by Smity42
further comments:
RE001s are probably a great tyre, but would be much more expensive yeah?
KU36s will probably wear pretty fast, since they are pretending to be a semi slick
tight ass talk imo!
4x Ku36 in 18/40/225 - $230ea. Got a slighlty better price from Option1 in person..
I dont have a long term "project car" thats worth establishing the relation with any workshop for that matter so the best deal will definitely get my business.
Call option1 up, $132 each for both 595SS and KU31, fitted.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
