John: its the actual tyre being noisy and not from lost of traction etc. Generally better gripping tyres are noiser than lesser gripping ones. And thats why I'm checking whats the best compromise between them.
Yep, I know. Was making a remark about how quiet/unnoticeable the tyres were, until they squealed. Other than that, we didn't hear tyre noise. Had the windows down too for the most part.
he actually knows that but he was commenting on it.. generally the 595 are quiet depending...
*nods*
is it a 300kw beetle?
I see what you did there :P
Thats the exact reason why I'm asking. I cbf about the noise on mine as the exhaust will be louder but on her beetle its different. The CR KAI I sold to my friend had some ling longs on them (cheapass) and I didnt know they're noisy until he put them on his cefiro. Its very annoying to hear thats for sure, sounds like bee buzzing.
Yeah come for a drive in mine. My car is very quiet when not getting up it so you would notice the tyre noise if there was anything noticeable. There just isnt. They are just a very competent tyre that do everything you ask of them.
Yea will do. You guys still doing the wash or what?
John: Got ERD to check the loading and speed stuff for 535.
Dave: I called him first but was disappointed with the price he quoted for KU31 (and other models too). Maybe he can offer a better price if you rock up but I highly doubt. The price difference between him and option1 is more than 100bucks for all 4 fitted and aligned.
No one can beat Option1 if they still want to make money on the tires.
They sell them the cheapest to sell more.
Like you always say, the best deal will get your business.
tight ass talk imo!
you can better business deals if you continue to buy from one place and always make it clear..
otherwise u will forever be running around looking for the best deals.
edit0- how much are they charging u a tyre?
Edited by Redsuns88
Question Guys!
I need some help with tyres here. Wife's new beetle gonna be here next month and she's getting 17s for the car, so obviously she'll need tyres. What would you recommend?
Model Noise Wear Price Grip TOTAL
RE001 2 2 1 2 7
KU31 3 3 3 2 11
KU36 2 1 2 3 8
595 SS 3 3 3 2 11
595 Evo 2 2 2 3 9
Size that I'm getting is 215/45/17 and judging from the price I've got here, KU31 (option1, cheapest) and SS (ERD, cheapest) are the best compromise between noise/price/wear. What are your thoughts?
KU31s or 595 evo. I have the KU31s on mine and they are extrememly good for the price.
Get the SS. I've got no complaints on mine. Brilliant everyday tyre.
I've driven on both the SS and KU31, the KU31 is much grippier. Can't comment on noise as I don't hear them over all the other rattles my car makes, or tyre wear as I haven't had the KU31s for long, but I'm much happier with the KU31 than the 595SS.
595 evos are meant to be better than the SS though.
Brandon... I'd recommend Linglongs.
LINGLONGS FTW!
+1 :)
535s are sh*t. don't even bother
Edited by Smity42
further comments:
RE001s are probably a great tyre, but would be much more expensive yeah?
KU36s will probably wear pretty fast, since they are pretending to be a semi slick
tight ass talk imo!
4x Ku36 in 18/40/225 - $230ea. Got a slighlty better price from Option1 in person..
I dont have a long term "project car" thats worth establishing the relation with any workshop for that matter so the best deal will definitely get my business.
Call option1 up, $132 each for both 595SS and KU31, fitted.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
