John: its the actual tyre being noisy and not from lost of traction etc. Generally better gripping tyres are noiser than lesser gripping ones. And thats why I'm checking whats the best compromise between them.
Yep, I know. Was making a remark about how quiet/unnoticeable the tyres were, until they squealed. Other than that, we didn't hear tyre noise. Had the windows down too for the most part.
he actually knows that but he was commenting on it.. generally the 595 are quiet depending...
*nods*
is it a 300kw beetle?
I see what you did there :P
Thats the exact reason why I'm asking. I cbf about the noise on mine as the exhaust will be louder but on her beetle its different. The CR KAI I sold to my friend had some ling longs on them (cheapass) and I didnt know they're noisy until he put them on his cefiro. Its very annoying to hear thats for sure, sounds like bee buzzing.
Yeah come for a drive in mine. My car is very quiet when not getting up it so you would notice the tyre noise if there was anything noticeable. There just isnt. They are just a very competent tyre that do everything you ask of them.
Yea will do. You guys still doing the wash or what?
John: Got ERD to check the loading and speed stuff for 535.
Dave: I called him first but was disappointed with the price he quoted for KU31 (and other models too). Maybe he can offer a better price if you rock up but I highly doubt. The price difference between him and option1 is more than 100bucks for all 4 fitted and aligned.
No one can beat Option1 if they still want to make money on the tires.
They sell them the cheapest to sell more.
Like you always say, the best deal will get your business.
tight ass talk imo!
you can better business deals if you continue to buy from one place and always make it clear..
otherwise u will forever be running around looking for the best deals.
edit0- how much are they charging u a tyre?
Edited by Redsuns88
Question Guys!
I need some help with tyres here. Wife's new beetle gonna be here next month and she's getting 17s for the car, so obviously she'll need tyres. What would you recommend?
Model Noise Wear Price Grip TOTAL
RE001 2 2 1 2 7
KU31 3 3 3 2 11
KU36 2 1 2 3 8
595 SS 3 3 3 2 11
595 Evo 2 2 2 3 9
Size that I'm getting is 215/45/17 and judging from the price I've got here, KU31 (option1, cheapest) and SS (ERD, cheapest) are the best compromise between noise/price/wear. What are your thoughts?
KU31s or 595 evo. I have the KU31s on mine and they are extrememly good for the price.
Get the SS. I've got no complaints on mine. Brilliant everyday tyre.
I've driven on both the SS and KU31, the KU31 is much grippier. Can't comment on noise as I don't hear them over all the other rattles my car makes, or tyre wear as I haven't had the KU31s for long, but I'm much happier with the KU31 than the 595SS.
595 evos are meant to be better than the SS though.
Brandon... I'd recommend Linglongs.
LINGLONGS FTW!
+1 :)
535s are sh*t. don't even bother
Edited by Smity42
further comments:
RE001s are probably a great tyre, but would be much more expensive yeah?
KU36s will probably wear pretty fast, since they are pretending to be a semi slick
tight ass talk imo!
4x Ku36 in 18/40/225 - $230ea. Got a slighlty better price from Option1 in person..
I dont have a long term "project car" thats worth establishing the relation with any workshop for that matter so the best deal will definitely get my business.
Call option1 up, $132 each for both 595SS and KU31, fitted.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
