lol when I got my r33 it had nankangs on it. Shit in the dry, deadly in the wet lol.
Josh - Will be a while before I'm putting anything close to the triple 8s on my car.
arent 888s as noisy as shit??? I went in a car that had them at a track day and the buzzed, screw that for a car i drive daily
I had RS's on my r32 and they lasted me a year (half of which i was driving 1000km a week), were not overly noisy but they were capablably of giving you a scare if they were not yet warmed up
daves seats look sexy. Go to group buy section n find the thread. Wouldn't mind some for the 31 but can justify paying that much for a seat when I barely paid that for the car!
At 200kph...
Like cum on a blanket in the wet too..
Arent 888s proper semis? If so I would expect them to be real noisy.
Josh i admire your dedication to grip because i would go mental....because at wakefield there is nowhere you are going anywhere near 200 and it was annoyingly loud through a helmet!
I'm a boy who likes to stick to things :) hhaha
Yeh they like to "hummm" a bit on the road.. My god 400rwhp/rb26/gtst pissing down with rain up nebo.. Yeh, just yeh. Very impressed.
awwwwww.... the seats are sprints :) I was hoping they'd be r100s or speed 2s
the speed 2 is the update version of the speed which is a update of the sprint v. i cant find the speed's in australia.
ive sat in a sprint v and its very close to the bride zeta. and for half the price you cant go wrong, and the material feels stronger.
if you want i could en-quire about them for you?
Edited by 32_Dave
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
