okay noobs.
Electrical is far better then a mechanical boost gauge. And no electrical doesn't mean that the gauge lights up its to do with the sender. defari if you go with tristans sugestion and order a autogauge electronic boost gauge you'll be more than happy and we should be able to work you out a good price 10% discount on rrp.
the gauge im referring you to is:
http://justjap.com/store/product.php?produ...=400&page=1
270 stepper motor = type of motor, with 270 degrees motion
peak recall = this recalls the max boost you hit during a drive, great for tuning you t-piece.
bang for buck you cannot go wrong, but if you have loads of cash by all means get defi's.
What can you do? Want to do? Dont care?
At the moment not really fussed hey. What I WANT to do, is pannel beating/spray painting. What I can do is a great range of things because I've done a bit of everything over the years. I just want the dollars rollin' in yo :):happy:
broad minded persons!
have to come to my shop today to have a beer with me!
pffft, as if drink that women's nectar :down:
Mechanical ftw
uhhhh... you might be thinking about analogue vs digital, brah :)
huh?
kevin you're killing me, electronic owns
+1
electronic ALWAYS better than mechanical (y)
+1
Rather do some research about the companies that make it if u want a more spot on accurate gauge..
Defi aka Nippon seki has been in the watch industry alot longer and thus more accurate guage
if u want cheap shit that looks like defis but not the real deal... more wiring and more hassle.. be like 32 dave and buy autogauge..
if u want less wiring, easier plug and play more accurate reading then defi is the way to go..
everyone will have their own thoughts..
yes defi are the shit,
and after them apexi and blitz are the best option
but for our application and bang for buck - autogauge is sweet
i mean just looking on nengun now - a defi boost gauge is $225, and that doesnt include the controller, whereas the autogauge is just under $100
it depends on your budget, what you want out of your car, and where you want to take it
autogauge has been in the game for a long time. and there not cheap shit. when you say more wiring and more hassle, doesn't sound like you'v had much to do with this series of gauge, they make shit very easy, it'd be less wiring then the defi's considering they need that control box. autogauge consist of getting power to 1 gauge and then it loops in and out through plug in wiring harness, then all you need is the sensor and the wire going to the sensor, i don't see how that's more hassle ???
sweet, i was gonna go and get one of those crappy sabre ones from autobarn for like 80 bucks, but yeah if you guys recommend the auto gauge ill go with that..
not looking to go big hp car, keeping it stock but just wanting to know what boost its running as it has a manual controller, not sure what its boosting at the moment..
Thats nengun's prices.. have u even bothered to look else where??
if ur not willing the spend the money.. then go buy some sabers.. cheap pos like autometer..
LOL
GL for accuracy too
Blitz and apexi guages are just like omori guages.. good but not that great..just wiring slapped togehter and sealed with braneded logo..
prob 10-12psi would sit nice, depends do u want an excuse for a new turb? Its just trial and error with the t-pieces, start low and wind you way up and use the gauge to tell you were u sit.
What are u two doing.. blowing eachother while sitting next to each other??..
sure autogauge been in the market for a while.. but its just like saying.. yea.. power and spirit products been in the market a long time too..
a control box?
one wire goes into that? and control box goes to a power source?
sounds like u havnt touch that either..
You do realise Autometer and Autogauge are owned and made by the same people in the US "Autometer" Just happens to have a huge range of gauges no matter your budget.
Have you even looked at their style of guages?
its just like Drift style gauges..
i think your better off going to patch up your shell mate if u want to talk products with me :happy:
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
