Hell yeah! Just spoke to the EFI boys and they are INNNNNN!.
What do they need to bring.
Awesome. They can bring their Rainman customers along to rip hektik skids on Webster Rd. Hopefully a truck will collect the lot of them. Failing that, the cop shop is just down the road. I imagine it'd be defect central from that workshop anyway. The cops'll have a ball!
updated the group buy, $400ea. :ninja:
John, no r100's sorry breh.
Thanks anyway mate - guess it's gonna be an import job
They want to know what to bring. Tissues...Icecream...Skidz??
hey lads i work at the regatta, i drive a black 32, its parked there most days, maybe some of u may have seen it? anyway just saying hi. i dont really have anyone to go for drives with so i usually go by myself. do u guys go on cruises much? id be keen to tag along some time. cheers adam
EOI at this point.
I need a hand to do a few things around the shop.. and i was wondering if you guys owuld like to pitch in and give a hand.
so i thought about holding a BBQ when the rain clears and shit like that... just a EOI at this present time..
BBQ/drinks. shit talking then need a hand diong stuff :ninja:
Yeah I'll help out if i got nothing else on whenever you organise it. What shit we gotta do?
updated the group buy, $400ea. :)
What about R200 longnose, 3.9:1 ratio?
:P
hey bro i think ive parked next to you a few times in my old grey r32
always welcome to join in on the fun :banana:
Hey man, what do you do at the regatta? I work just behind you guys at the honda joint. Haven't seen your car though, then again, don't usually go into the carpark there.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
