as much as i hate watching that proactive and miricle blade shit...i'll still sit there and watch it, not like there's anything else to watch. What ever happened to all the calling in guessing words games. Just realised they were all gone. Probably for the best.
The word games were on earlier than the infomercials!
They were usually hosted by some loser from big brother or something equally as horrible and displayed just how stupid the population of this country can be. So I'm glad they're gone!
and every day is a good day for a day off :banana:
Yeah that's right. I remember why i hated them now. But yes, i just wanted a taste of your good life john. Tried to sleep in but body clock wont let me.
Maybe its time we organize for a dinner at southside!
On a side note, isnt this the 33gtr driven by a chinese guy that rocked up the at the car wash?
http://www.skylinesaustralia.com/forums/95...le-t293695.html
Just checked it and it is! That was a quick disposal.
Wheres those photos Michael? Check the plates!
sth side dinner sounds good. with or without cars? (piss up?)
just checked the pics and yes, that is the one we saw few weeks ago at the wash. what was wrong with it tas? or was it the black one...i forget.
Yea sounds good. Little Singapore??? Hahaha. Or maybe just go to Tas' favourite place, the old "Shiok". I'm sure John (southside John) would be up for it.
Both have something wrong with them... Hahaha. Black one's got some weird sound from gearbox, clutch or something. Silver turbo sounds like its dying. I remembered he mentioned got that gtr for 17k...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
