Have a yarn with zenon Josh, Thats about where he's at with some carefully thought out spenshun mods and he has a ball in that flat capper of his.
Yeh might hit him up. My teins gotta go! no question there. Dont even think they are worth trying to save with less silly spring rates in them
T51Z on a stock rb20, and then change the timing belt.
and then fit a new intercooler.
then some more parts.
then wait a couple weeks
RB24 is a waste of time.
Plenty can be done with the RB20. Need to spend a bit on cylinder head work though if you want the numbers and torque.
Leave the bottom end for now, take off the head and put on a pre-ported one with bigger valves etc. Go Pon cams, Angry German with surge tank injectors and a NISTUNE or I have an ECU in my 20 which has already been chipped and I won't be needing it. Already set up for 550's and a Z32AFM
I can't use AFM with the new setup as there is nothing big enough for 1rwkhp
So all you'd need would be injectors, fuel system, JJ intercooler and a couple of other bits and pieces. Could easily get 220rwkw on that turbo.
Then when you can afford more of an upgrade (or even want one) do the cylinder head and go bigger turbo/cams. You can make 235rwkw on the stock cams with stock/untouched head.
You can also do 205-210 rwkw on stock injectors and AFM too but I would be careful running them at those levels.
Is it worth toying with cam gears? Or not worth it unless I went to a full ECU?
Worth my time buying a 6boost manifold for the current turbo? (I have no views of going high mount/ex gates).
The key is, response, keeping it alive and staying consistent
No, stay factory manifold but maybe heat coat inside and out.
easy to keep it alive but revs will have to be cut short at 8k until you can afford/want bottom end work. And I'm not talking about beat kind of bottom end work.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
