that seems like a lot of effort to go to...
sounds like you're just out of download and want me to hook you up!
Nah man.. I'm doing the kids of the world a service. I'm trying to get rid of all the pron on the internets. If I d/l it all no one else will have it. Just wanted to give you a heads up so you could get some before i got it all .
ok maybe no martin - that dog is running too much camber :P
HEY! I have nice camber now
Yep got crappy tyres.
Well there's ya problem :P. Naah but as the other guys have said, too many variables. Sounds like you MAY benefit from more front camber, but could be plenty of other things as well.
R33 stocko rims for sale! without tyres! pm!
How much?
heyy... theres a remote on the desk, and a tv mounted on that pillar.
Anything decent on tonight?
Hi Geoff! ;)
I now know why dad was bugging me to come pick up the ute - my birthday present is in the tray :). Pics as soon as I get it out (or find some on the internet).
EDIT:
:D:thumbsup::cheers::banana:
Edited by Smity42
This is all of brisbane water mains.
end lesson
Nope its all carp.
Do i get square eyes? Sometimes :cheers:
1 hr to go til beer o'clock
:thumbsup:;)
I'm actually going to ask a serious question.... I think i'm ill
I recently got coil overs and underbody kit and etc.. Now I've got 17" 235 ( standard size tyres ) after I got the coilovers etc done it scrubs on the guards and understeers like a bsatard and spins the rears in the wet. I spoke to a fella from a tyre place and he said that it would be because the tyres are like this | | and not like this / \. Is that the case here ? Or am i missing something? If the tyres are like | | less traction and understeer ? / \ no understeer and heaps of traction ?
It's possible the camber is wrong but I think you'll find that the spring rates are too high.
What brand coilover?
XA extreme's
Ahh Pedders.
Any idea on the spring rates?
If not, can you tell me the coil outer diameter, number of coils including the flat ground ones, thickness of wire and total height?
Ahh Pedders.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
