Martin by any chance were those two smoking hot cops in the area of Albion/clayfield? cause if so its true, they are actual cops. I have seen them before. Many an early morning RBT setup in that area, its one of our test drive runs (rougher roads in the backstreets there, good for testing for suspension noises)
Spot on: Clayfield. I think its Melton Rd, near the corner of Junction rd
the big operation? or a job?
Yer there is a couple hotties working around that area, pretty sure they are from hendra. Also some hot ones working for fortitude valley station
When I got pulled over by an RX8 in Ascot a few months back, the chick that spoke to me had tigs that put Terri to shame!
Edited by Isola
Watched this on SBS. Very weird zombie movie with aliens in it. Weird but kinda cool. The sheila in it has four pump action shotguns mounted together.
worth watching?
what country?
I <3 Zombies
It was a good watch actually. Especially the way they brought in the aliens. I think it was a oz movie.
I'd give it 3 "brrrraaaiiiinnnnssss" out of 5
Its almost as good as that NZ zombie filum
That i'd give 4 squidgy innards out of five.
But nothing is as good as Shaun of the dead..
Farkn lol love that movie.
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
