Jason, you need to buy all these accessories for your car:
You can get them all from here:
As long as you're at least this big:
lol he cant afford it! :( its too classy for a country bumkin like him :P muahahaha
Isola buy a DS !!! i want epic mario kart battles at work!!!
u know u want too!! u can drift in it tooo!!!?!?!??!?
ok thts 2k posts time for work!
We discussed this yesterday :( I'm not buying a freaking Nintendo!! lol
Edited by Isola
muahahah
*puts on wizard hat and robes*
battle me isola
*pulls out DS with mario kart*
or i shall not release the red beast!
speaking of red beasts - hows the supra going mang?
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
