in that case im not asking nice at all :/
a week for a clutch and service is ample time :)
2 hrs is ample time if you don't need to wait for a flywheel to be machined.
did u dig up a old post to try and hurt me? lol HOR HOR HOR HOR!
Old posts? It was 2 posts earlier, nub
That looks like a fire I lit once in DBay
no need to worry about it because it'll be done and sweet by next weekend :)
BAHAHAHAHAHA joo make me laugh
Martin:
If I buy the beers, would you like to help me install my head unit and kill switch?
As long as its good beer, or bundy and coke :/ . Wasn't your kill switch(s) going to be an epic project?
isola u said it wrong..
ur supposed to be like if i give beers and blow would u do it? lol
He's too old to be allowed to blow me
I'm not blowing Martin. If wanted your spit in my mouth, I'd kiss you.
That offer to help has just been revoked :)
Edited by Smity42
7 weeks at best
Oh, and the drift switch :)
MUNGIIIIEEEEEE!!!!!!!!
In before Dan!!
OMFG, you are a psychic. Or is that psycho?
Ok im off to work for a couple hours fun!
so morning post for me!!
Sucks to be you going to work at that time
Oh Hai
ladies
got one quote to fix the crack in my rear bumper, due to some asshole reversing into me
$500
farking joke
This is why insurance is good
Insurance wouldn't have made a difference. Never saw the guy who reversed into it, so would have had to pay the excess, which on imports is usually at least $500
limp bizkit = worst and you two will burn in hell for quoting it
lies!
everyone was into limp bizkit at some point in their life
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
