Oh and if i can get $350 for each AFM and $800 for my shitty power FC i will be happy! Good ecu here i come!
Correct me if I'm wrong, as you may be talking about another set of AFM's or PFC but the AFM's on the white GTR are actual Z32 AFM's. It has an Apexi (I think) power intake to suit Z32's and I actually bought them myself from CRD.
The PFC also has no hand controller.
Were you referring to the GTR stuff?
Did you end up getting that clutch? How was it?
nope
obviously you missed the posts involving my "quality turbo install" or lack there of :D
so now ive taken my car else where, and am awaiting word on a quote for the whole job in one hit
this job which includes a different clutch..
just a button this time - 5puck i believe, not the 3puk one from before - but yeh cant confirm
ahh ok. Hope it works out for you then.
Nothing better than being able to enjoy your car once it's all fixed up again
yeh - one stop, everything gets done properly and i drive away with no worries :D
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
