The head unit is fine, plugged it in at JB and powered straight up.
I've got the car at an auto electrician today, asked them to go over it top to bottom. Figured I should do that seeing as the brake lights are on the fritz and the reverse lights are intermittent and I'm getting them to double check that alarm so it works properly and actually ALARMS when the door/bonnet/boot open. Y'know... what it was made for lol.
So hopefully the dirty FO' won't have any more wiring troubles by the end of the day :D
Cool, hopefully they sort it out and it doesn't cost you too much
good news,
keep us posted ;)
+1
+1 For awesome Saturday night. We met one lucky motherf**king possum.
Walking from the carpark to work today was unf**kingbelievable. Theres just bitches everywhere! Find out if I get the unit I put an application in on today so fingers crossed eh ;)
Walking from the carpark to work today was unf**kingbelievable. Theres just bitches everywhere! Find out if I get the unit I put an application in on today so fingers crossed eh :happy:
oh hai bitches, buttsecks? ;)
and hells yeh for yo appartment :D
In before heterosexuals.
And no Josh, I don't believe that. Having said that, though, I know where you get your cool from. Your Dad is a Ballplaya! (That's a cross between a Balla and a Playa)
Hahah, oh yeh. Isn't he just.. Those right wing liberals are off the chain
hey, just a quick question, would anything go totally wrong if i reset the ecu in my car?
also correct me if im wrong.. disconnect negative bat terminal, pump the breaks for a bit.. reconnect negative and turn on again?
Edited by defari
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
